When exporting to LBS for Open bridge, I get the following error : "LEAP Bridge Steel application could not be found in path"/.
I have LBS installed and it will open and run on its own. How do I resolve this error?
LBS seems to have not installed correctly. Please uninstall LBS and install it again with an account that has admin privileges and also set the User Account Control Settings to "Never Notify".
When the product is installed correctly you should see the following in the registry:
Answer Verified By: Michael Alestra
I am getting this exact same error. I have the reg key per instruction above and I am in the admin group. Running windows 7 tested this on two different machines. Both have the same message when attempting to export LBS from OpenBridge Modeler v 08.11.11.72
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
