Anyone can help me, how to assign expression in cross-section?
To assign expression for RM Bridge cross-section in Modeler you Modify the respective Segment on the bottom tab Variables and Apply Expressions From / To Segments Points as in the screenshot below.
Variables are previously defined for each Cross Section position in the Distance Tab at bottom right while their evaluation is set at Tables and Formulas.
Marcos Beier
Senior Technical Support Engineer, Bridge
Bentley Systems Inc.
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 2 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Answer Verified By: MarcosBeier
