OBM - Deck creation errors
I'm creating a deck with varying thicknesses throughout the span of the bridge. The first part of my deck looks okay and I'm able to apply a constant thickness to it of 6'-3".
The second part of the deck I want the deck thickness to transition from 6'-3" to 10'-3. I've assigned my variable constraints (6'-3" at the start and 10'-3" at the end). Here is what I'm getting:
Right side (deck thickness varies from 4.70 feet to 7.38 feet):
Left side (thickness varies from 6.45 feet to 10.64 feet):
Here is a view from underneath:
The two variable constraints I've applied:
Thanks for any feedback on what might be causing this.
Eric
