Hello everyone
Am new with RM and was wondering if anyone could help.
Anyway when ever I generate my model am getting warnings such as these:
W1934: Wizard Bridge1: Omitting cross frame 'LB' at position 1.000 (Left) - 1.000 (Right) of span 'S01'-'Bay01'. It overlaps with another one!W1934: Wizard Bridge1: Omitting cross frame 'LB' at position 1.000 (Left) - 1.000 (Right) of span 'S01'-'Bay02'. It overlaps with another one!W1934: Wizard Bridge1: Omitting cross frame 'LB' at position 1.000 (Left) - 1.000 (Right) of span 'S01'-'Bay03'. It overlaps with another one!W1934: Wizard Bridge1: Omitting cross frame 'LB' at position 1.000 (Left) - 1.000 (Right) of span 'S03'-'Bay01'. It overlaps with another one!W1934: Wizard Bridge1: Omitting cross frame 'LB' at position 1.000 (Left) - 1.000 (Right) of span 'S03'-'Bay02'. It overlaps with another one!W1934: Wizard Bridge1: Omitting cross frame 'LB' at position 1.000 (Left) - 1.000 (Right) of span 'S03'-'Bay03'. It overlaps with another one!W1934: Wizard Bridge1: Omitting cross frame 'LB' at position 1.000 (Left) - 1.000 (Right) of span 'S04'-'Bay01'. It overlaps with another one!W1934: Wizard Bridge1: Omitting cross frame 'LB' at position 1.000 (Left) - 1.000 (Right) of span 'S04'-'Bay02'. It overlaps with another one!W1934: Wizard Bridge1: Omitting cross frame 'LB' at position 1.000 (Left) - 1.000 (Right) of span 'S04'-'Bay03'. It overlaps with another one!W1934: Wizard Bridge1: Omitting cross frame 'CF' at position 0.000 (Left) - 0.000 (Right) of span 'S03'-'Bay01'. It overlaps with another one!W1934: Wizard Bridge1: Omitting cross frame 'CF' at position 0.000 (Left) - 0.000 (Right) of span 'S03'-'Bay02'. It overlaps with another one!W1934: Wizard Bridge1: Omitting cross frame 'CF' at position 0.000 (Left) - 0.000 (Right) of span 'S03'-'Bay03'. It overlaps with another one!W1223: Element 80001: multiple usage of element number.Element 80001 used at segment w1_P01, point 1.Element 80001 used at segment VStiffR, point 1.W1223: Element 80011: multiple usage of element number.Element 80011 used at segment w1_P02Cap, point 7.Element 80011 used at segment VStiffR, point 1.W1223: Element 80031: multiple usage of element number.
What am I going wrong?
Warnings are suggesting to delete some of the cross frame LB and CF as it overlaps with others at some positions.
There is also a multiple usage of the exact same elements numbers in Stiffeners and Caps.
You might need to review those.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 5 hours ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
