Is there a way to vary a deck slab width along as a chord? if i vary it linearly along a curved alignment i still get a curved deck. I want a straight line variation between to the two ends of the deck slab. Is this possible?
Mike, You should be able to draw an alignment line (a simple chord) in the DGN, and set the deck - Point Constraints, to follow this line.
Thanks,Sri
