OBM - Abutment Display Error
The depth of my Abutment Pile Cap displays correctly when shown in the "Edit Abutment" window but is not being shown correctly in my 3D model.  It is currently shown being shown much deeper.
I also have a few general comments/suggestions regarding future enhancements:
- Provide ability to automatically adjust footing off of multiple controlling terrains.  There are some areas that my footings are controlled by existing ground and some controlled by proposed ground.
- Ability to copy up 3D shape to dgn to add visualization features.  Currently if I want to show this to a client I have to export it to a google sketch up format and then re-import it.
- Vertical clearance - clash detection is ok for knowing you have enough vertical clearance in some locations but this is a bridge/transportation specific tool.  Being able to define a corridor and have it look for and call out minimum vertical clearance would make this a more intelligent model.
  • Reviewed Kyle's model, and responded directly. Abutment had large negative elevation constraint, and this was controlling rather than the depth specified in the abutment properties dialog.
    Great suggestions for future versions of OBM.
    Multiple DTMs: We are working on introducing user input Top of Footing Elevation, so user has some control in these kind of situations. Multiple DTMs need to be investigated.
    Regarding “Ability to copy up 3D shape to dgn to add visualization features”, another workaround:
    communities.bentley.com/.../126559
    Corridor vertical clearance: I agree, we certainly need something specific to bridge.
  • "We are working on introducing user input Top of Footing Elevation, so user has some control in these kind of situations."
    I hope this is implemented soon. We are trying to come up with a workflow on how to model an existing bridge condition. It would be very beneficial to be able to specify an actual top of footing elevation based on as-built information. This will help with clash detection for proposed bridge work and utilities.
    As it is now, can I get information off a footing in OBM and see what the TOF elevation is?
    Eric
  • Eric, The user input Top of Footing Elevation should be available in the next commercial release of OBM, i.e. V8i SS 2, tentatively planned for January 2017.
    Yes if you select the footing in the tree view, you should be able to see the Footing Elevation as shown in the image below.
  • "Eric, The user input Top of Footing Elevation should be available in the next commercial release of OBM, i.e. V8i SS 2, tentatively planned for January 2017."
    Great. I look forward to the next release.
    "Yes if you select the footing in the tree view, you should be able to see the Footing Elevation as shown in the image below."
    Thanks for the tip. That is great to know and until the next release I can work backward by adjusting the column length to control the top of footing.
    Eric
Reply
    Eric
