LEAP Steel 16.02.00.02 - what changed?
the release notes for 16.02.00.01 and 16.02.00.02 appear to be identical, what is the reason for this new update?
  • The LBS16.02.00.01 release has gone out in error with the capability of creating tub girders which is currently is not ready to be used or to be designed.we are actively working on completing the tubs capability in the next LBS version, but version V16.02.00.01 should not be used at all. In V16.02.00.02 the capability to create Tub Girder has been deactivated and everything else is similar to LBS V16.02.00.01 .
