LEAP Concrete - view concrete section properties?
I have a Reinforce concrete T-Beam bridge modeled (with varying girder depths along the span). I have the reinforcement placed as well. Since the girder depth and steel area vary across the span, is it possible to view the moment/shear capacity of the members at particular sections along the girder as an output from Leap Concrete?
As an example, would there be a breakdown of a rating? It would be nice to have a table or output where I can see section capacity, dead load and live load effects. Just seeing the rating values doesn't give me any confidence that the rating is correct without digging into other outputs and reverse engineering the rating values.
  • Hi ,
    1) if the user wants to check the Moment /Shear capacity or rating at a particular point on the span other than every 10th point.
    2) Then the user needs to click on "Points of Interest" on the Model TAB and then input the POI on the span where they want to check all the relevant informaton.
    3) Then once the Analysis is done and the T beams are designed.
    5) Click on the PRINT button and then  select FINAL option in front of case.
    6) Then under Misc. Reports select Detailed Moment/Shear capacity .
    7)Click on Enhanced Reports and then clickon Create Reports.
    8) Then in the new output report user should be able to see the Detailed Moment/Shear capacity at every 10th point as well as at the POI.
    9) User can use this information to cross check the rating results.
    Please see the attached screenshots for more information.
