is there a way to locate the prestress strand horizontally?
i want a strand pattern to look like this:
but i seem to only be able to place them like this:
From the screenshot it looks like you have set the Section offset at the end of the girder and that's the reason you are unable to see the strand pattern as per the CAD drawing.
Please move the section offset scroll bar to 0.5 L then you should be able to see the correct strand pattern as shown in the CAD drawing.
Please see the attached screenshot.
