I have a model that I exported from OBM to LBS. Im checking the translation and I see an issue. The beam layout in LBS is correct in the dialog however when i export the dgn of the beam layout from LBS and reference it into OBM, the beams for a particular span aren't lining up. the baseline from the beam layout and all other spans are where they should be but the beam lines in this span are off.
the beams from OBM are the pink lines with the red circles and the OBM layout is green with the yellow perpendicular lines at the ends. The OBM model measures correctly, the LBS dgns export does not. I have no other way to verify if the LBS model is correct beside what is shown in the dialog. Not sure if there is an issue with the LBS model or the output.
