<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>is it possible to get accurate quantities???</title><link>https://communities.bentley.com/products/bridge_design___engineering/f/bridgemaster-lars-leap-openbridge-rm-forum/132832/is-it-possible-to-get-accurate-quantities</link><description>i&amp;#39;d like for OBM to be able to report accurate quantities.
 i have a bridge 7 girders, 60&amp;#39;-93&amp;#39;-60&amp;#39; spans, W36x170.
 that quantities are just a bit off (32.9lbs???). i guess cross frames aren&amp;#39;t important either? whats worse is i cant even grab the volume</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: is it possible to get accurate quantities???</title><link>https://communities.bentley.com/thread/406572?ContentTypeID=1</link><pubDate>Tue, 21 Mar 2017 11:00:14 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:0e6ec929-5321-4760-bd66-8f1b14696010</guid><dc:creator>Vinay mysore</dc:creator><description>&lt;p style="margin:0in 0in 0pt;"&gt;User needs to assign a material for the beams (in the beam definition dialog) and the cross-frames and stiffeners (in the library), after which you will see the correct report.&lt;/p&gt;
&lt;p style="margin:0in 0in 0pt;"&gt;We use the unit weight from the material properties to develop the quantities (weight).&lt;/p&gt;
&lt;p&gt;&lt;span style="font-family:Times New Roman;font-size:medium;"&gt; &lt;/span&gt;&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
