LEAP Bridge Concrete's publicity materials (www.bentley.com/.../9007.ashx) indicate that it has the capacity to export to Excel. I know LBS can do this. How do I do this in LEAP Bridge Concrete (version 16.02)? I am trying to export all of the pier reactions and camber information to use it for bearing design.
Once the user Runs the analysis in the Analysis TAB. Select the Load case or Load combination or envelope strength and from Effect heading select the Force or moment option or Displacement & Rotation option and then once the analysis results are populated then click on PRINT button on the top right hand corner and then select the option "Current selection to Excel File or All Combination to Excel File" and then select the folder where the file needs to be saved and then click OK.
I hope it helps. Please let me know if this is the information you are looking for.
Please see the attached screenshot for more information.
