Any sample tutorial for concrete design code check? because the example in the program are more focusing on the modeling and analysis.
Usually you can find RM Bridge Concrete Design Code Check only at the Part2 documents. Check the image below for your reference.
Sample tutorials are at File\Examples\TrainingExamples. If you select Training Example 02b. Prestressing AASHTO and hit OK you´ll also need to select a Final Stage or Finalized Example to have access not only to the modeling in the Part1 of the documents. In this example if you access the respective documents at Description there are Fiber Stress, Reinforced concrete, Ultimate load capacity, Shear and Fatigue Checks in lessons 21 to 25 at pages 41 to 50.
Best regards,
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 2 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Answer Verified By: IronMaxSteel
