We are using RM Bridge Advanced version V8i 08.11.28.02, we have started using wizard function to model and input and we encounter some errors during analysis. kindly refer to attached screenshot 1 & 2 and also attached herewith the model file for your checking.
Also we have some other inquires as below;
1) As we have set the project into BS Code under wizard, the design code is BS code whereas code group is in eurocode.
2) No live load result (eg. Traffic, Braking, Seismic & etc) on Precast Girder under RM-Set
Appreciate if you could go through our model and highlight to us mistakes, error in imputation or configuration that we have might missed out.
Thank You
For detailed support with datasets please create a Service Request at https://connect.bentley.com/
1. Apparently you´re coherent with the material and checking Codes as BS is special case of EC.
2. RM-Set results need the Schedule calculations to be performed.
Also need to check the stresses and define reinforcement areas.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 6 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
