Can somebody help me how to print report in RM Bridge, I find it very hard, there is no direct tab to print report unlike other software just go to file print report and etc.
Thanks.
Access Results in the Navigation Tree (as highlighted in green below) or at the top Menu and select one result. There are two options: Diagram and Print, at bottom right (as highlighted in blue below).
There are several other options like including Plot and Diagram Set inside the Schedule Actions to automatically generate graphical results.
For the new release even the new implementation for stress leading results is available to report when selecting the parameters.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 2 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Hi Marcos,
Thank you for your help,
Is there an easy way to print all the report all diagram and etc., it seems like I have to print 1 by 1 per page.
Same below, how to print this results in 1 click?
