Can OBM add a parameter of cross slope when placing a deck? This parameter can be used to control the rotation of the deck with an angle around the centerline. And auxiliary also need a parameter like this.
When placing a deck, you do have an option in the variable constraints, to specify either a "Rotation by Angle" or "Rotation by Slope". Note that both of these are marked by asterix symbol (*), next to them, to denote that these are system created variables, and are available for every deck template automatically.
A similar option for Aux does not yet exist. Could you elaborate on a use case for the Aux placement ?
Answer Verified By: ZeGan He 何则干
As shown above, there is a diaphragm plate along the centerline in every 2 meters, and I need to use the function of placing auxiliary to place it. When the box beam has a cross slope, the diaphragm plates also need the some cross slope to fit it.
