When placing auxiliaries by path along a curved bridge, the auxiliaries will not in the right position if the start and end stations are not set as same as the start and end stations of the whole deck.
2.dgn
ZeGan He, Not sure if I understood the problem correctly. But on the curved bridges, you could also use the "Guideline Provider" option rather than picking the alignment and specify the aux. along selected points on the template. Perhaps that would solve the issue.
AS seen in the picture below. In my case, I choose “select guideline provider” as the path selection mode, pick the P_1 as the guideline point of the inner side, pick the P_5 as the guideline point of the outside, set the start station with 5 and the end station with 18. You can see that both of the Auxiliaries of the inner side and outside are not in the right position at the end station 18.
3.dgn
Dear Sri
This issue persists in version 10.07.03.23. Is it a bug?
