Leap Bridge, not seeing the option to copy Field Splices from Member to member. The help indicates it is possible to copy "Once field splice locations are defined on a member they can be copied to other selected members or all members. " BUT not seeing the tools to do this. How is this done? I am looking for something similar to the copy bearing stiffeners or cross frames, am I missing something?
Version 17.00.00.04
I confirm that in V17.00.00.04 the option to copy Field Splices from Member to member is not available and the help file has not been updated.
The solution to this issue is that the user has to manually input the field splice information.
It would be fantastic to have a copy feature. Can the suggestion of a copy feature be forwarded to developers? Thanks
