Is it possible for both to reference in a single alignment file (stored on projectwise), thus changes to that alignment file would result in updated OpenRoad and OpenBridge Models?
Ryan,
You can reference a dgn file with the alignment into OBM, and use it as the primary bridge alignment. Once you are notified that the alignment has changed, simply open up OBM, and hit the Update Bridge button. This will cause the bridge to react to the changes in the alignment.
Regards, Sri
Sri, Thanks for your prompt reply - is there any guidance on how I can reference the OPENRoads DGN file alignment in OPENBridge Modeller? I cant find any material in the help files or online . . .
Ryan, Please see if this video will help. https://www.youtube.com/watch?v=qWLgHnBvDd8
Thanks,Sri
