From playing around with the software I see several options for not having these overlap
Are there other ways of accomplishing this that I haven't thought about?
Carlos: you could turn off the bridge deck display after you have it modeled assuming you have also modeled the deck as part of your corridor.
Thanks Steve. Modeling the bridge deck using a separate "deck" template in the corridor would work. I had not thought of that. Of course that would mean you would still have some overlap with skewed abutments.
Anyone else use this or any other method?
Carlos Lopez, PE, M.ASCESenior Engineer Parsons CorporationNewark, NJ Phone – 973.735.5403 Carlos.Lopez@parsons.com ♦ www.parsons.com
