Bearing Spacing Dimensions Differ Between Main Bridge Model and Substructure Module
I am designing a 2-span precast prestressed beam bridge in LEAP Bridge Concrete CONNECT Edition v17.00.01.01.
The bearing dimensions along the pier cap are shown correctly in the following view under the 'Substructure' tab:
However, when you click on the 'Substructure' button to open the substructure module (formerly RC-PIER), the bearing dimensions along the cap are incorrect:
Why are the bearing spacing dimensions differing between modules?
Parents Reply Children
