Hi, Dear All,
I found a bug when I tried to update "Type of Duct" in the CONBOX model as in the attached picture. I am able to update "Type Of Duct" and the "Friction Coeff" will be updated accordingly. However, after the model is updated and saved, if we close and reopen it, the "Type Of Duct" goes back to "Rigid/Semi Rigid Galv Metal". It seems that the "Friction Coeff" remains the same, however the wrong "Type Of Duct" is kind of annoying. Could you please verify and fix this possible bug? Thank you so much for your help.
Dong
I would like to inform you that this issue resulted in Defect 785733, and will be evaluated by the product management team for our regular SELECT updates. Any other users that encounter this issue can also log a Service Request to be informed of changes.
Answer Verified By: Dong Wang
Hi, Dear Vinay,
Thank you so much for the help.
