How do I modify the beam template to have skewed ends as detailed by TxDOT for skewed bridges? Currently, the beam ends interfere with the abutment backwalls. ftp.dot.state.tx.us/.../igebsts1.pdf
We do not want to put the beams on a skew but rathre clip the ends where it hits the skewed abutment backwalls.
In Leap Bridge concrete currently it is not possible to skew a portion of the beams at the ends (As shown in the PDF file).
Thank you. Is this the same in OpenBridge? Also, would the beam ends interfering with the abutment backwall affect analysis for either LEAP Bridge Concrete or OpenBridge?
It should not affect the analysis in LBC or OBM
