How model debonded straight strands tendon in RM bridge?
What are the difference between type length sl--b, sl-e and dl-b, dl-e (as picture below)?
Thank you so much.
To model debonded straight strands tendon in RM Bridge you can use both the tendon types Internal or Pre-tensioned. The difference between type length sl and dl (as in your picture) is that Sleeve lengths are the covered distances where ducts create a distinct region with unbonded tendons and Development lengths (available also as Tendons loads in DEVLL\R) are the transfer zone where prestressing forces grow incrementally from 0 up to when they become fully effective. This happens because if there is no anchoring device there´s not a full bond immediately at the end of sleeve lengths.
When F1 - Help explanation is not sufficient you can always search for additional information in Help \ Manuals \ User Guide and use a keyword to search the .pdf document. This information for example is mainly at section 6.4.1.12 at page 105.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 6 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Answer Verified By: MarcosBeier
