I am getting the following error while trying to transfer the OpenBridge Modeler model over to LEAP Bridge Concrete to complete the girder design.
Error: LEAP Bridge Concrete application could not be found in path.
Currently running LEAP Bridge Concrete 17.01.00.36 and Open Bridge Modeler 08.11.12.88
Please advise,
Thank you!
Hi I am having the same problem. Please see attached file for versions and the message. ThanksDOCX
uninstall the OBD program.
Delete all the OBD folder from C: drive
Then delete the computer registry entries to find the installed/last used version of component applications.
As per the screenshot the verson is V17 and in your case it might be V22.
Please delete that folder and then reinstall the program .
I hope it works.
