We've run into an issue where files created in the Precast/Prestressed Girder module in LEAP Bridge Concrete sometimes are not able to be opened after we save and come back to our work. We attempt to open the file and it will begin to load, then it stops and nothing happens.
Is this a known issue? Are we perhaps saving wrong?
Evan Jones
Once the model is created in Precast/Prestressed Girder module in LEAP Bridge Concrete . Please close and update the file and then save as .lbc file.
Then open the file in the main LBC window itself.
I hope it helps.
Ran into the same problem with LBC (not just the conspan module). Copying and saving the file with a new name, and opening the newly named file solved the problem
When sending model from OBM > RM please be sure that *.xml path file name is filled.
For more information about RM v11.13 please look at the following link:
communities.bentley.com/.../275603
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Answer Verified By: MarcosBeier
