Hi,From time to time, when adding point control for my deck I'm getting an error saying "Error creating solid. Self intersecting sections detected. Please verify template dimensions and constraints". What that means and where the error might come from? Thanks.
Regards,Krzysztof
I'm having the same issue. The support for OpenBridge is really weak, and the software has no descriptors for what is supposed to be input in the various variable constraint data entry points.
Is there any way to get some help with this software?
Krzysztof, This typically indicates that the solids could not be generated internally based on the constraints specified. Since you indicate these are not based on dimension constraints, but on point constraints, it is not possible to use the verify tool to play with the dimensions and check for errors. Most likely when the point constraints have been set to a path, there must be something going haywire on the solids preventing them from being generated.
Can you please file a support ticket and send us the file and details, so we can investigate further.
Giles, please reach out to the technical support team for OpenBridge Modeler, by filing a service request.
connect.bentley.com
I've read thatdeleting and recreating features such as holes may help to fix those warnings.
https://essays.agency/buy-research-papers.html
https://my-surveys.com/foot-locker-survey-www-footlockersurvey-com/
