Im in LEAP Steel and have started a model all the way up to entering the supports. I click ok and get error message "Roadway limit is breached". All my supports are within my begin and end station, I am doing the same as I have with successful models. I cant find anything in the help manual. Any help appreciated.
See to that the alignment doesn't go beyond vertical orange line . let me know if it works.
Thanks, I did this. But am still receiving the error.
The solution I provided should work in your case.
The other solution is to reduce the length of the alignment and try to limit it.
Thank you. What do you mean by "try to limit it"? May I send you the file?
