I am looking for the difference between Load Case "HL-93" vs Load Case "HL-93 (Deflection per AASHTO)". When running the reports, I see two parameters: HL-93, and HL-93 (Deflection per AASHTO). What is the program doing differently to these two cases? The deflection results of each are drastically different.
HL-93 -- The deflection information in the live load output report on the analysis tab is total sum of both the full truck and lane deflection, and does not follow the deflection criteria of AASHTO 3.6.1.3.2.
HL-93 (Deflection per AASHTO) -- Design Truck 25% is created in the library for HL-93 (Deflection per AASHTO) vehicle description.
Thank you,
I am also looking in help for the meaning of "25%". Can you direct me to the loading differences between "Design Truck" and "Design Truck 25%"?
Thanks.
What version of LEAP do you use? I don't have HL-93 per AASHTO. thank you
LBS V18.00.01.10
