Is the rating factor calculated by capacity divided by the applied load? I am getting rating factors less than one AND performance ratios less than one. That doesnt seem to make sense considering they are inverses of eachother. Unless the LEAP calculates rating factor different than I expect. Where can I view the equation that is being used to calculate the rating factor?
Program should be using similar Rating equation.
The following rating articles/equations are used to determine load rating resistances.
Answer Verified By: MarcosBeier
