I am editing loads to change from HL93 defaults to HS20. The extent of this ability that I can determine is deselecting "Include Lane" to achieve HS20. Is this correct, or is there additional options to achieve HS20?
Create a new vehicle in the Library by clicking on ADD --> Modify and then Save it to the library .
Then in the Loads Dialog box you should be able to select HS20 truck.
