The horizontal shear demand in Conspan is determined using Vu which includes beam and slab effects (noted in the output), is there an option to ignore beam and slab effects? If a beam is simply supported when the deck is poured, the beam a slab effects should not contribute to the horizontal shear demand at the interface between the girders and deck.
I found the answer to my question - It is under Design Parameters on the Analysis tab.
