Hello!In the LAYOUT feature under GEOMETRY tab of CONBOX, I cannot continue the analysis whenever I set one CONNECTION as SPRING (with values). I am always ending up in an "UNKNOWN ERROR" message. Can someone please shed a light on this one?
Many thanks in advance!
Please let me know which version of conbox you are working on.
Please provide the screenshot of the layout and also the spring constant that has been applied.
Here is the screenshot of the LEAP Bridge i am using...
here is the screenshot of the layout...
and here's the error message when i clicked "run analysis"...
I may have to test this issue .
I tested this issue in V14.00.00.19 and inputted same spring value and I was unable to replicate the issue as I did not get the unknown error.
I will try to re-install the program and run the same model.Thanks for the verification.
If you are still having issues then please email me your conbox file to Vinay.mysore@bentley.com
Issue solved!Thanks a lot, Mr. Vinay!
