Hi All,
Can I do a bridge composed of reinforced concrete precast beam channels in Leap Bridge Concrete? None of these beams are prestressed on post-tensioned, so I want Leap Bridge to check it simply as reinforced concrete with steel rebar.
yes in CIP RC/PT Girder it is possible to check the beams simply as reinforced concrete with steel rebar.
Reinforced concrete with steel rebar must be tested by universal testing machine.
