Hello!
I am having issues with member groups in Leap Bridge Steel causing issues with bearing locations. My alignment is offset from from center of bridge 15ft to the right. In the first screenshot below, I have shown that the left and right edge of slabs are not correctly lined up with the visual provided. Is this a common occurrence?
My first picture did not post correct. Here is what it was suppose to be:
Some of these bearing offset issues have been resolved in latest version.
I would suggest you to download the latest version from Bentley select server .
the latest version is
