How does one set up a deck slab template when the profile is not located at the alignment? In my case the cross-sectional shape of the deck is shaped like a simple gable roof but the grade line is not located at the peak (where the alignment is) but rather 23' to the right side. If I create the template with the WP at the alignment, then the deck will be placed too low because of the crown drop. Please tell me how to do this or point me to a video describing this issue.
Hi Bill,
You can use the standard template and add variable constraints for the things you'd like to control. See attached screenshot of the ones i typically add to get what i need from the default template: LT_Width_Lane1, LT_Slope_Lane1, RT_Width_Lane1, RT_Slope_Lane1, Thickness
OpenBridge Modeler - 10.10.00.85Microstation - 10.16.02.34
Comprehensive 3 Day OpenBridge Modeler Training
