Data in 2 tables written by RM Bridge
Please answer !
According to some training examples of RM, they take data in PT-sum load case, so they have just ignored the values of Elastic Shortening during creating combinations?
This is a combination in a RM example
In the case of tendons that are not yet grouted they should be influenced by subsequent tendons; so, it might be the case that at the Recalculation Pad in theExtended Settings options Special Settings option "Include el. comp. losses for ungrouted" should be selected.
You can find a good explanation, documentation and example of Elastic Shortening at File/Examples/DEMO Examples & FAQ/ Concrete Structures - Prestressing - Elastic Shortening.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 6 days ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
