Moment capacity with CONSPLICE
I am modeling a precast post tension girder with CONSPLICE. I do the analysis and then go to the design to check moment capacity. I get  a set of results. when I do the summary report or shear check and go back to the moment capacity, I get a different result. I wonder if anyone has experienced similar issue and any possible solution to this problem.
  • Ramtin, such program behavior was reported, especially in past releases.  This happens especially if there are many changes done back and forth as it is the case with new users of the program.  There is a possibility that the user tries to force invalid data under input or the actual intended changes are not getting considered by the program.  In this case results may be based on previous input.  The simplest way is to open two instances of the program side by side and re-input your model from scratch.  Please also ask your IT person to install the latest release of LEAP Bridge Concrete v18.2.2.3.
    This is a test
Reply
    This is a test
