OBM - Place Custom Pier
Has anyone had successfully defined a custom pier based on the parametric cell that contained 3D solids and was included in PierCellLib.cel library? The "place custom" in OBM Rel3 does not define as such pier, however, it is possible when the standard MicroStation Cell Library tool is used. Unfortunately, with the last option, the pier is not linked with the bridge definition.
In addition, is it possible to define the sloped/inclined columns in the standard templates for piers in Pier Library?
Parents Reply Children
  • Pawel,
    We can use a little trick for now. You can place 2 piers on the same support line, so for one pier model the superstructure as you want and for the infrastructure insert some very small values for the dimension (no piles). In this way, the infrastructure will become just a small dot.
    In the same manner, create a new template for the infrastructure where the columns and caps have small dimensions.
    Issues:
    - take care with the quantities
    - you will have issues at transfer to analytics
    - if you will create excavations be careful to select the correct pier that has the footing that you want
