How to create Line Integral exactly? The example and the manual apllication is not enough to imitate and understand. Does any one can help me?
Hi Nghia,
Step-by-step to create an specific Line Integral Result:
In Modeler: Clic to create a Line Integral
Don´t type the reference name to be used (default will be the next available Int03), select the FEM Element (the Web highlighted below) and click Next
Then, click at bottom and top FEM Nodal points to create the reference line
The end of the points selection should looks like below:
Then, just right click to confirm and end the operation.
A Reference Set was created as below:
In Analyzer you can check the references created at Structures\Bodies\FEM...
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 1 day ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
