I am modeling geometry and bridge in Bridge Parametric Layout (GEOMATH).
I need help with bearing rotation. Even if I select the orientation with respect to the piers, the bearings do not align parallel to it. How can I rotate the bearings?
When I create the bridge, it does not include any girder referencing support. According to the manual, girders continuous over consecutive supports cannot be added. However, in my model, there are 2 separate spans. So, how can I include girders which should be included in the bridge reference list?
Beam Seat Orientation can be changed with respect to Girder or pier.
you can use Girder Layout wizard to add girder
