I have a multi-span bridge to be modeled in LEAP Bridge Steel. The bridge doesn't have abutments and it has two cantilever girders at two ends. Is it possible to create this model in LEAP Bridge Steel? Thanks a lot in advance
Yes , I believe it is possible . Instead of Abutment, model a pier at the first station and extend the girder by providing longitudinal offset.
Please let me know if it worked for you.
Thanks for your reply. However, I did not see a longitudinal offset option in girder definition. Could you please show me an exact location?
Thank you
I tried myself to model cantilever girders but it is NOT possible in the current version of LBS.
I did double checked with the development team as well.
I apologize for the inconvenience.
No worries. Thanks for your confirmation.
