Modeling of Bilinear spring for rotation
I can not find how to build a modeling of bilinear spring, specially for rotation.
It means that moment and curvature, moment-curvature curve, should be considered.
There is no example.
Anyone could explain me how to make a bilinear spring?
If there is example then it is better.
  • Hi,
    In RM Bridge you can create a table in Analyzer/Properties/Variables.
    Then modify the Spring at Structure/Elements/ElementsType to one of the several non-linear possibilities.
    You can select a stress strain diagram as shown below.
    Apply the Variable name to the rotation in the Specific Values for each DOF- Degree Of Freedom.
    More advanced options are also available.
    Also check the video RM Bridge bilinear springs with hysteretic behavior below:
    https://youtu.be/TDnpZIdollQ
    Marcos Beier
