We are currently running ProjectWise Connect with OpenRoad Designer using Managed workspaces. We are trying to get OpenBridge Designer working within ProjectWise using the same managed workspaces. After installing OBD and then ProjectWise I have to open OBD outside ProjectWise because it doesn't recognize that it has ProjectWise. If I open OBD outside ProjectWise I can open OBM but OBM doesn't see the ProjectWise Managed workspace. If I tell OBM to "create" a new workspace it opens the ProjectWise folder structure but I cannot tell it the project, or where the workset is. I have tried to find documentation on how to configure OBD or OBM with ProjectWise and managed workspaces but all I can seem to find are references to OBM "should" open ProjectWise files, which it can. It simply does not open the managed workspaces associated with the file.
Any help is greatly appreciated. I don't mind reading if someone can point me in the right direction.
Thank you
Phillip Hess
