Hi, I am new to RM bridge analysis. Through wizard i could model deck bridge and prestress bridge taking box girder.
i am not able to understand how to model cable stayed bridge. The PhD shown in help is not clear to model it. Can anyone help me in modelling.
You can find an example at File/Examples/Training Examples 07. Cable-Stayed Bridge where you can import the dataset for your reference and follow the instructions at the .pdf document.
Work in the Modeler part creating the Alignment in Axis and then the Cross Section, Main Girder and Piers Segments and Cables...
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 2 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
