I am having trouble extracting the dead load deflections from my Leap Bridge Steel model. I have run the analysis with no issues, but cannot seem to get the dead load deflections. I have tried two different ways and both have been unsuccessful. I am running Leap Bridge Steel Version 18.02.00.12.
The first way I tried to extract the dead load deflections was trying to view the report under Dead Load-->Node Displacements. I select all of the proper parameters and when the report is displayed there are no values. It just shows dashed lines for everything (x,y,z displacements and rotations).
The second method I tried was using the Camber Diagram. I select the load cases which I want the deflections and the table below shows 0.00 inches for each load case.
I know there are dead load deflections as I can see them visually under the analysis tab.
Is there another way I can get the dead load deflections from my model?
Thanks for the help.
Zach
Please download the latest version of LBS V19.00.00.20 from Bentley Select server and check the dead load deflection issue and let me know if you are still having issues.
Hi Vinay,
I downloaded the latest version of LBS and I am now able to see the dead load deflections from my FEM analysis model. Thanks for your help!
You are welcome. i'm glad the issue is resolved.
