I'm using OpenBridge SS3. Is it possible to insert additional longitudinal lines for deck elevation reporting? For instance, I need to export the elevations along PGL (4' offset L & R), but there is no physical element such as a slope break point or barrier, etc., so I cannot select that line from my "Common References" list when running the deck elevation report. I added the points to the deck template, so the model recognizes a joint at 4', but still doesn't show in the Common References list. Any other way to add arbitrary lines to the report?
Hi Laura,
The deck elevation report gives you the possibility to specify offset points along the bridge length. These points are tied to existing elements like alignment, deck edges, barrier edges or beam layout. If this resolves your problems, please suggest this post as an Answer.
Answer Verified By: MarcosBeier
