In Leap Steel Bridge V18.02.00.012 I had a working model. Today, I upgraded to 19.00.00.27 and the model no longer works due to overlapping slabs error.
I've gone through the inputs and THINK I have pinned the issue down to my substructure alignment offset.
The black line in the image above is generated when I inputted the offset of my alignment for the substructures. However, the line is not continuing to the end of the bridge. If I delete the slab sections that are at the end of bridge without the centerline, the slab error goes away.
Any thoughts on why the offset alignment is not continuing to end of defined roadway section?
