Yesterday I was working with a couple models (Piers) with different loads applied on it. Everything was working properly; however, today, I modified some of loads. When I tried to run analysis, I get a message: "Frame Analysis Failed! Frame Model Unstable". I wonder what could cause the problem, and how to solve it. From my view of point, this failure is related to the software because I also tried to run analysis for one of the tutorial files, and I got the same message. If anybody knows how to solve it, I'd appreciate to share with me the solution.
Please email me the file "Vinay.Mysore@Bentley.com".Please let me know which version you are working on.
I changed the size of the drill shaft and then changed the fixity to Spring and i did not get any warning message.
communities.bentley.com/.../leap-bridge-concrete-main-page
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
I know this is old, but is there a resolution or a work around? This is happening to me as well. I'll make a small update, (column location, bearing change, etc.) and this will happen and I can't run the model.
