Hi COmmunity, I am using RM Bridge, But How to Model Cable Stayed Bridge including the stagging analysis calculating nonlinear effect, it is not very clear in the PDF file. If possible, could you give me the turtorial in English from you tube.
Second, the PDF tutorial given in the software is not really match/with the TCL file. Somehow it contains error.
I use RMV8i
Hi Ariono.
Our YouTube Channel can be found here: https://t.co/e4pUzFKPer
As there is no complete class there you can find better reference for trainings at our LEARN Server at: http://learn.bentley.com/app/Public
Thank you for your alert, we had just updated the CSB class with a new documentation that matches the datasets and user interface so it's available in the current release.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 1 day ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Answer Verified By: Ariono Dhanis
When the cable stayed bridge will be released ?
